Author Topic: New name for class not showing when code generated  (Read 3229 times)
« on: August 16, 2005, 06:38:44 am »
Good morning,
I created a data class named EquifaxRawData.  I renamed the class to EquifaxData but when I generate the code, it is being sent to EquifaxRawData instead of the new name.
I am currently using verion 4.5 build 740.  I tried searching to see if this had been reported as a bug but did not see it anywhere.
Has anyone else seen this problem?  If so, has it been fixed in a release?  We normally do not upgrade until one revision after a major release to give time for problems to shake out.
Ok, some more information.  I had generated source code with the old name.  If I delete the generated file and then generate the code, EA picks up the changed name.
Richard
« Last Edit: August 16, 2005, 07:28:03 am by [email protected] »
Re: New name for class not showing when code gener
« Reply #1 on: August 16, 2005, 07:43:12 am »
I'm no code junkie but you might need to adjust the filename in the properties window. Probably this will not synch...
« Reply #2 on: August 16, 2005, 08:17:05 am »
That was how we changed the name of the class.  To check on our "hypothesis" I opened the .eap file with notepad and did a search on the old name.  Voila!  The old name and file location were still stored in the .eap, just nowhere that we could get to to change.  As I noted, when I deleted the generated code with the old name and regenerated the class, it "fixed" the problem.
Thanks for the suggestion, though.
« Reply #3 on: August 16, 2005, 10:22:29 am »
You should look into the properties window (View/Properties). There's a Filename which points to the generated file. Likely this name is not synched when you rename the class. You can edit this field as usual.
« Reply #4 on: August 16, 2005, 04:25:01 pm »
Thomas is correct.  The filename is not updated when a class name is changed.
Additionally, the code generation will be unable to find any class that has been renamed, and will add a new class into the file.
Simon
