Author Topic: Default not overridden on Import  (Read 2201 times)
« on: August 18, 2005, 05:16:01 pm »
I reverse engineered some C# code into a new model file (for testing purposes).  The default language is set to Java on new model creation.
When I imported the directories I told EA the source type was C#.  However, when it created the packages for each namespace, it created them with language Java, not C#!
While acknowledging that if I created a new package manually, it should use Java, when I've told it I'm importing C#, it should create C# packages!
