Author Topic: Specifying Part Multiplicity on Composit Structure  (Read 3264 times)
jeshaw2
« on: August 20, 2005, 08:22:47 am »
Ref: OMG UML 2.0 specification, 9.3.12 Property (from InternalStructures), page 194, Presentation Options...
Figure 115 shows the two options for showing a property's multiplicity.  I like the mark in the upper right corner best, but would be satisfied with the cardinality notation suffixed to the name.
How do I accomplish this in EA?
I've created a CompositeStructure Diagram in EA.  Using the Class tool, created an 'owning' class.  I enlarged the class symbol to allow nesting of the 'owned' parts.  Using the 'Part' tool, nested a part in the class.
The 'Part' properties do not provide a place to specify multiplicity (how many instances of the Part is owned by the class).  ???
Two points:
  • Not all Parts are associated with other Parts; and
  • the cardinality of connected parts can be different from the cardinality of the connector ends.
For example: a Car may have four wheels, only two of which are connected to the engine. Therefor, the cardinality of the connector ends does not relate to my problem.
Jim
AshK
Re: Specifying Part Multiplicity on Composit Struc
« Reply #1 on: August 21, 2005, 05:05:19 pm »
Hi Jim,
Please right click the Part and select Advanced Settings->Set Multiplicity.
Ash
jeshaw2
« Reply #2 on: August 21, 2005, 05:19:44 pm »
Thanks!  Works great!
Jim
