Author Topic: Exclude notes from Diagrams in RTF documentation  (Read 4314 times)
perlaursen
« on: August 19, 2005, 05:03:15 am »
Hi
Is there any way to exclude the contents of the "Notes" field for a Diagram when generating RTF documentation? That is, I want to include the content in the HTML documentation, but not in the RTF documentation.
Best regards,
Per Laursen
sobedi
  • No comment.
Re: Exclude notes from Diagrams in RTF documentati
« Reply #1 on: August 19, 2005, 06:59:39 am »
You should specify which generator you are using and
if you are using the new RTF-Generator, which Template.
perlaursen
« Reply #2 on: August 23, 2005, 02:21:57 am »
I'm using version 4.51.749 of EA, with the corresponding RTF generator
« Reply #3 on: August 23, 2005, 03:54:21 am »
The diagrams in the RTF docu are just rendered images. They look the same as on your screen. So (AFAIK) it is not possible to place any rendering option for diagrams.
perlaursen
« Reply #4 on: August 23, 2005, 04:39:49 am »
Hi
I may not have expressed my problem clearly enough; when I say "Notes", I here refer to the textual contents of the "Notes" edit box in the "Diagram Properties" dialog. It is not the "Diagram Note" (with Name, Author, Version, etc.) you can choose from the toolbar.
Hope this clarifies the problem (for which I still hope there is a solution :))
Best regards
« Reply #5 on: August 23, 2005, 05:04:16 am »
Your last post makes it clearer, but still: old or new RTF generator? Both are corresponding and I don't know whether they both did exist with 749 already.
perlaursen
« Reply #6 on: August 23, 2005, 05:29:01 am »
Well, I guess it must be the old RTF generator then, since I don't see any way of choosing an alternate RTF generator in version 749.
Thanks for your efforts.
« Reply #7 on: August 24, 2005, 05:11:05 am »
Hmm. I played around with the old one, but there is obviously no option to suppress the diagram notes (exclude details for...) :-/
« Last Edit: August 24, 2005, 06:04:59 am by thomaskilian »
