Author Topic: Hide sequence connectors  (Read 2346 times)
jstonecash
  • So many possible mistakes, so little time!
« on: August 29, 2005, 07:03:09 am »
I have a class with a class diagram and a sequence diagram.  When I generate a RTF report and I select the connectors in the sections list, I get the all the connections in the class diagram and the sequence diagram.   I would like to suppress the sequence connections (the sequence diagram should be sufficient for what I am trying to do).  I have played with the "Exclude Details For" list in the document options but it does not seem to have any affect on what I an trying to do.
From reading this forum, I know that I could attach a sterotype and filter on that but then my sequence diagram is messed up.
Is there a way to filter out the textual material generated from the sequence diagram but not mess up the sequence diagram itself?
Re: Hide sequence connectors
« Reply #1 on: August 30, 2005, 05:43:09 am »
AFAIK there is no way to do what you want. Probably you can run two reports with different options and merge the results?
