Author Topic: Major panix - major oops  (Read 3430 times)
sargasso
« on: September 05, 2005, 11:24:49 pm »
Omiomiomigawd.
Somehow I have now got two versions of the test EAP file.  One has got a single use case with a huge chunk of tests entered on the weekend and the other is the backup from Friday night which has been used since Monday morning - new use cases and tests.
If I export the missing use case from the weekend file and import it into the current live:
1) will it bring the tests (t_objecttests not "test" elements) with it?
2) is it likely to clobber any EA db structures entered since then?
bruce
AshK
Re: Major panix - major oops
« Reply #1 on: September 06, 2005, 12:01:37 am »
Hi Bruce,
We're just taking a look into this now...
Shall respond asap.
Ash & Ben
benc
« Reply #2 on: September 06, 2005, 12:17:40 am »
Bruce,
1) Yes - XMI export/import will bring in the tests
2) Yes - If you XMI import the same package over the top of a copy, the copy will be clobbered.
So to avoid the clobbering either check the strip guids XMI option when importing your weekend work into the Monday morning model or :
1. Open your weekend model and drag the Use Case into a fresh package.
2. XMI export the fresh package
3. XMI import the fresh package into your Monday morning model
4. Drag your weekend Use Case to it's original package.
I hope this helps.
Ben
sargasso
« Reply #3 on: September 06, 2005, 03:35:33 pm »
Thanks guys - look like it worked a treat.
bruce
