Author Topic: Repeat last connector and stereotypes  (Read 3782 times)
colinc
« on: September 11, 2005, 07:13:59 pm »
I'm not sure if this is a bug or just an 'it doesn't quite do that'.
I am using the Erikkson-Penker extensions for some analysis, which require a reasonable amount of stereotyped associations.
When I use repeat last connector (F3) it will happily let me create an arrow etc. but it doesn't remember the stereotype that has been applied to the connector.
Not a major problem just a minor annoyance...
Re: Repeat last connector and stereotypes
« Reply #1 on: September 12, 2005, 12:12:11 am »
Just tried here with 770 and <<supply>> - no problem ???
colinc
« Reply #2 on: September 12, 2005, 05:29:36 pm »
I just upgraded to 770 and tested with <<supply>> and <<achieve>> and it didn't work??
Maybe this is specific to the elements or diagram type.
I'm using an Analysis diagram ; and have tested it from Objects to Objects; from Objects to proecesses and from actors to processes.
Very strange?
Colin
« Reply #3 on: September 13, 2005, 01:01:32 am »
I tested with Object/Object on also an Analysis Diagram. Works perfectly. I'd recommend to send a bug report to Sparx and accompany it with your model.
