Author Topic: Code Generation with Namespaces  (Read 2799 times)
Andreas_G
  • And that's the way the cookie crumbles.
« on: September 20, 2005, 12:22:03 am »
Hi Folks,
I have a problem with namespaces during code generation.
This time, I don't have the problems with generating the namespaces again, it's a problem with classes that refer to other classes in other namespaces.
One example:
I have classA in namespaceA. And I have classB in namespaceB.
classA has a method with a parameter of type classB: myFunc(classB).
normaly the code generater should create something like this (C++):
namespace namespaceA
  classA
                              myFunc(namespaceB::classB b);
But it generates this:
  classA
                              myFunc(classB b);
Since the namespaceB is missing on the parameter b in myFunc, the compiler didn't find classB and can't compile my code.
Any solutions?
bye
Andreas
bye
Andreas
AshK
Re: Code Generation with Namespaces
« Reply #1 on: September 20, 2005, 04:37:00 pm »
Hi Andreas,
I can successfully generate the right code using build 770.
The only way that I've been able to achive the results that you are getting is if package B is set to a namespace root.
Please ensure that this is not the case in your model (right click package B, select Package Control->Clear Namespace root).
Hope this works,
Ash
Andreas_G
« Reply #2 on: September 21, 2005, 04:30:09 am »
I found the problem. It was a bug in our code generation templates.  ::)
Thanks for your anser Ash
bye
Andreas
