Author Topic: Enumaration problem  (Read 2744 times)
hangryman
Enumaration problem
« on: August 26, 2005, 08:29:07 am »
I can't find the enumaration to use in my class diagram.
In the help they say "Drag an Enumeration item from the Profile section of the UML toolbox onto the diagram. "
but in the "UML Toolbox" the "Enumeration item" does not existe.  ???
How can I create an enumaration?
« Last Edit: August 26, 2005, 08:29:39 am by hangryman »
Re: Enumeration problem
« Reply #1 on: August 26, 2005, 08:45:17 am »
Check your settings.  You must have UML 2.0 as your workspace perspective and then you must also have the Profile folder checked in the UML Toolbox section of the Tools|Options Dialog.  Finally, the Enumeration button must be checked for the Profile folder.
That should then make it visible.
dmantilla
Re: Enumaration problem
« Reply #2 on: September 21, 2005, 08:52:30 am »
Do you know if this will generate an "enum" data type in C#?
« Reply #3 on: September 21, 2005, 01:04:07 pm »
A quick look at the C# CTF templates would suggest not.  But try it... If not, you can amend the template to test for it and change what is emitted.
