Author Topic: Exporting from Visio UML to EA - how?  (Read 5833 times)
mbc
  • Embedded software developer
« on: September 22, 2005, 08:55:30 am »
We have a model in Visio Professional, that someone has spent a long time on creating. We would like to continue working on it in EA.
Unfortunately, I haven't been able to find a way to export any usable format from Visio, e.g. XMI.
From what I could read in some other threads, I think it must be possible, but I haven't been able to find out exactly how?
Thanks in advance,
Mikkel
Re: Exporting from Visio UML to EA - how?
« Reply #1 on: September 22, 2005, 01:50:51 pm »
Does that help?
mbc
« Reply #2 on: September 23, 2005, 12:11:54 am »
Sort of.
I had found something like that, but I was hoping for a solution that didn't require me to build my own plugin. I also found a similar plugin example for Visio 2003.
Amazing, that MS did not provide built-in XMI export. Anyway, nice to know that apparently there isn't any better way around it.
I haven't been able to get this plugin example to work. I found someone with Visual Studio who could build it for me, but the menu item that I think should appear, just isn't there.
If there is someone out there who has actually succeeded in exporting any XMI from Visio (2003), I would like to hear from them.
Best regards,
Mikkel
mbc
« Reply #3 on: September 23, 2005, 12:42:24 am »
Hello again,
I don't know exactly what has changed, but today the XMI Export menu item decided to appear in the Add-ons menu. Maybe it's because the sun is shining outdoors. ::)
Now I have run into a new problem: The UML.DTD supplied by  Sparx apparently does not fit the XMI exported from Visio. Can anyone help me find a suitable UML.DTD? MS claims that it is downloadable from omg.org, but I can't find it there.
Mikkel
« Reply #4 on: September 23, 2005, 01:58:24 am »
Again not very helpful :-[
mbc
« Reply #5 on: September 23, 2005, 02:05:20 am »
From the same discussion:
Yeah - I spent a number of fruitless hours trying to import (so-called) XMI that Visio had puked up Sad
This is the process I have also started, but I will have to delay it until later, because I have something else, I need to finish today.
I did find one of the DTDs from here, that sort of works:
http://www.omg.org/docs/ad/
but there are still problems.
I will return later, if I get any further.
Mikkel
« Reply #6 on: September 23, 2005, 02:48:18 am »
Good luck. There are obviously people who will be grateful for a solution :)
