Author Topic: how to create an empty project?  (Read 7570 times)
chrvi
  • There are so many hidden features...
« on: September 19, 2007, 02:28:28 pm »
Hi there,
I've always worked through Java API with an existing .eap file but how can I create new such a file (containing let's say one class view model)?
I bet I've seen it discussed somewhere but...
All your hints are welcome.
Radek
« Last Edit: September 19, 2007, 02:29:20 pm by chrvi »
Radek
Re: how to create an empty project?
« Reply #1 on: September 21, 2007, 01:25:55 am »
File/New ?
If you are talkig about DB repository: chose the above to create an empty EAP. The create a new DB as usual and transfer the empty EAP into that.
« Reply #2 on: September 21, 2007, 03:24:14 am »
Or actually create an empty template project, stored someplace predictable. Through your API copy the template to your target location and name. Then open it as usual.
chrvi
« Reply #3 on: September 21, 2007, 03:41:44 am »
Well, actually I'd like to create a brand new .eap via automation interface without any prepared existing .eap files somewhere.
I do not want to be dependent on some storage with an empty .eap file.
It'd be fine for me to create it on the fly...
Radek
« Reply #4 on: September 21, 2007, 03:43:52 am »
Then why not use the good old COPY? Create an empty EAP manually, then copy it...
« Reply #5 on: September 24, 2007, 01:14:52 pm »
Even EA can't do this.  It relies on EABase.eap being in the same directory as the executable.
bmioch
« Reply #6 on: September 24, 2007, 07:08:18 pm »
chrvi, when EA creates a new project, it copies the EABase.eap file from the install directory of EA.
chrvi
« Reply #7 on: October 01, 2007, 10:43:43 pm »
I see... OK.
Thanks, guys.
Radek
