Author Topic: diagram stereotypeS ?  (Read 6281 times)
moses
« on: October 06, 2005, 12:58:27 am »
hi,
did any of you succeed to setup diagram stereotypes ? We haven't. Via profile it did something else, and via configuration, there is no option for diagram ...
Thanks, regards, Moses
Re: diagram stereotypeS ?
« Reply #1 on: October 06, 2005, 03:42:37 am »
You can when using the diagram properties window. It does not much sense though, since the stereotype does not appear in the Project View not can it be used for anything else except in automation :-/
moses
Re: diagram stereotypes ?
« Reply #2 on: October 06, 2005, 10:14:10 am »
yes thanks, i meant whether there is a way of filling up that combobox in diagram properties ...
i just found out that even though the combo in Configuration > stereotypes doesn't offer "diagram" as a base class, i can write it on my own and it works :-). Still not for the uml profile though.
