Author Topic: Deployment Diagram  (Read 4170 times)
gluzm
Deployment Diagram
« on: October 05, 2005, 06:54:36 am »
Hi all,
when I am creating deployment diagrams and are using nodes then after I place one node into diagram and then another "inner" node into the previous node then EA is creating hierarchy visible on the left side "Project view", this also works when I just move some node into the hierarchy then it is visible on the diagram as inner node.
But once I instantiate the node then this functionality is not working the same way. If I move another instantiated node into its parent node then the hierarchy is not created on the left side, and also when  I move it into the hierarchy on the left side then it will not get visible on the diagram?
Why is it working that way, or is there any flag I have to check to get this displayed?
« Last Edit: October 05, 2005, 07:03:36 am by gluzm »
Re: Deployment Diagram
« Reply #1 on: October 05, 2005, 01:38:39 pm »
Dragging a node onto another doesn't change the project view. It just hooks the inner on the outer one. So I'm curious how you managed the change in the project view.
sargasso
« Reply #2 on: October 09, 2005, 07:45:56 pm »
Why is it working that way, ....
"that way" is tied up in the z-order of the elements in a drawing.  If node2 is higher than node1, then dragging it onto node1 makes it a child element and moves it in the project tree.  If it is lower then it doesn't move it.
..., or is there any flag I have to check to get this displayed?
No.
I don't understand you here, what do you mean it's visible as a child node?
bruce
