Author Topic: how put my classes in a package?  (Read 4611 times)
jercoli
« on: September 02, 2005, 06:46:30 am »
Hi, I've build my classes in a diagram; then i've create a new diagram of packgages; and then... assign the correct classes into the correct packages: how make these: not work with copy-paste, neither with drag and drop.
My Model is:
- Logical View (i´ve see the packages)
 - Logical Model  (see my classes)
 - Data Model ...
Thanks in advance.
Re: how put my classes in a package?
« Reply #1 on: September 05, 2005, 12:56:55 am »
... assign the correct classes into the correct packages...
??? what do you mean with that?
sargasso
« Reply #2 on: September 05, 2005, 03:11:28 pm »
Are you trying to drag drop the classes in the project tree or on the diagram?
cschleif
« Reply #3 on: October 10, 2005, 09:08:17 am »
i have the same problem.
i've reversed engineered my java source and then I clicked on
a package and then on "New Element" and added a class.
after this I try to "generate code", this works fine, but when I looked at the source I saw that the package isn't set.
is there an option to link the class to my package? did I forgot something?
« Reply #4 on: October 10, 2005, 01:13:03 pm »
A mystic thread. What do you mean by "I saw that the package isn't set"? Can you give an example?
« Reply #5 on: October 10, 2005, 05:34:52 pm »
My Model is:
  - Data Model ...
Thanks in advance.
Open the project view, you should be able to drag classes between packages in there.
Make sure that your new class is in a package that isn't set as a namespace root.  Packages are generated for all packages that aren't namespace roots.  (Search the help or this forum for "namespace root" for more information)
cschleif
« Reply #6 on: October 11, 2005, 01:04:39 am »
okay i solved it by saying "Create Package per Directory" this
works also.
but anyway thanks  :)
