Author Topic: Class Diagram in early version  (Read 2748 times)
cesar.fonseca
« on: October 13, 2005, 12:20:45 pm »
I have a Class Diagram in early version of enterprise architect, and i can't open this in enterprise architect 5.0.
Somebody can help me?
thanks.
Re: Class Diagram in early version
« Reply #1 on: October 13, 2005, 01:00:39 pm »
Can you describe what you're doing? In short steps?
Bruno.Cossi
« Reply #2 on: October 13, 2005, 01:40:01 pm »
Which version of EA did you create the model in? As far as I know, when you open an older version of a model in newer version of EA, EA automatically upgrades it (it does ask you first). Perhaps if there is difference of multiple versions you may have to go stop-by-step...
Bruno
thanks.
cesar.fonseca
« Reply #3 on: October 13, 2005, 01:42:16 pm »
Thomas,
i trying file/open, and returns the erro:
"this is a version: 3.11 database. To remove replication you will need a base project(.eap file) of the same version. "
I can't find it in the sparxsystems web site
« Reply #4 on: October 14, 2005, 12:00:37 am »
Try the following: make a copy of the repository (e.g. Base.EAP). Go to Tools/Data Management/Remove Replication. Select your main repository and it should show the current version. Go on to next screen and select the Base.EAP. You should now be able to create a new EAP without replica information. I don't know whether the base must be without replication ???. The newly created EAP should in turn open without problems.
If it does not work, ask Sparx [email protected] directly.
« Last Edit: October 14, 2005, 12:14:33 am by thomaskilian »
