Author Topic: Conditional RTF Generation Possible?  (Read 2871 times)
wink
  • Montjoie, que jamais ne choit!
« on: October 20, 2005, 02:48:41 am »
Hello everybody,
Sorry I've got another question for you  ::)
Is there a way to generate some rtf fields under certain conditions?
As an example:
If I have a Class with 2 methods, one with arguments called "A" and another without arguments called "B".
MyClass::A(int,int) and MyClass::B()
I would like to generate a title for the arguments only for the method that actually has arguments.
A() method
arguments:
 x : int
 y : int
B() method
Another problem is that I can't put a an element field in the method section like:
element >
method >
{Element.Name}::{Meth.Name}() method
< method
<element
This will not generate anything for{Element.Name}
Any help is very much appreciated!!!
thanks in advance,
best regards
Manfred
Best regards,
Manfred
sobedi
  • No comment.
Re: Conditional RTF Generation Possible?
« Reply #1 on: October 20, 2005, 04:54:32 am »
Thats not a bug, its a feature...
the new rtf editor is a buggy thing since day 1.
In each tag you can only display elements and fields of the  element tag.
You have to do the following:
element >
{Element.Name} method >::{Meth.Name}() method
< method
<element
if you're lucky it works,
if not you have to start a new template and start all over again.
Sometimes deleting previous inserted spaces may move element tags...
wink
« Reply #2 on: October 20, 2005, 05:03:11 am »
hi sobedi,
thanks for your reply, I actually feared that I would have to do something like this... buggy, buggy  ::)
;D I'm more used to hear that from another firm (Micro$oft) they also say "this is by design"... ;)
cheers,
Manfred
Best regards,
Manfred
