Author Topic: Diagram icons missing in PostScript/PDF output  (Read 2881 times)
cnahr
« on: October 26, 2005, 02:29:42 am »
(Looks like nobody's reading the Suggestions forum, so I'll repost here...)
When you create a package diagram of a namespace, EA will put small icons next to all elements that differentiate classes, interfaces, and nested namespaces.
Those icons also appear when saving to a graphics file. They are replaced with monochrome icons when printing to a HP PCL printer.
However, when printing to a PostScript printer or to Adobe's  PDF creator, those icons are completely missing. Only the text appears.
The workarounds are not satisfactory: exporting to a graphics file either renders the text as bitmaps (= ugly) or shows the icons on a black background within the yellow/gray component boxes (= also ugly).
I can't imagine that this should be hard to fix, given that EA already has dedicated for-print icons which are correctly used when printing to PCL printers.
So could you please fix this, so that we get proper icons in PostScript and PDF output? Thanks.
Re: Diagram icons missing in PostScript/PDF output
« Reply #1 on: October 26, 2005, 03:01:58 am »
If you don't get a reponse here, it's likely that you're the only one with that problem. In that case you should contact Sparx directly via Bug or Support mail request.
cnahr
« Reply #2 on: October 26, 2005, 06:05:29 am »
Thanks, I wasn't aware of the dedicated bug report page and thought the Sparx folks would monitor this forum anyway. I've submitted a bug report now.
I think it's rather unlikely that I'm the only one who ever tried to create a PDF file from a package diagram, though, and I can't quite imagine what would be special about my system to produce such an odd bug...
cnahr
« Reply #3 on: October 26, 2005, 11:34:15 pm »
Well, that was quick! Sparx Support has replied to my bug report -- it's a known bug which they hope to fix in the near future. Meanwhile, the workarounds are creating an RTF report for the diagram, or saving as an image.
