Author Topic: XMI Export EA to Rose fails  (Read 3788 times)
RalfK
« on: October 26, 2005, 06:16:22 am »
Hi!
I have -maybe- some basic problems.
I try to export some diagramms (use-cases, activity) from EA 5.00.772 to Rational Rose Enterprise Edition using XMI.
Rose is giving me a lot of error messages like
Bad type for getSourceX function: Association at EAID_315B8318_4CE6_4f61_938B_E9E7B55A6E14.
Bad type for getTargetX function: Association at EAID_315B8318_4CE6_4f61_938B_E9E7B55A6E14.
Nearly nothing is imported by Rose.
As a newbie, I need some hint's to understand  what's wrong here.
I've seen some statement about "bad XMI support of Rose".
But, an exchange of simple diagramms should be possible!?
Do I run in a "never get to run" problem, or is it more a newbie problem and someone can tell me which button to press to run it? :-)
Thanks for your help
Ralf
« Last Edit: October 26, 2005, 06:17:31 am by RalfKneisle »
Oliver Michalski
Re: XMI Export EA to Rose fails
« Reply #1 on: October 26, 2005, 07:40:29 am »
Hi Ralf,
try this:
In the Exportmenu select Unisys/Rose Format and  Exclude EA Tagged Values
Oliver  ;)
RalfK
« Reply #2 on: October 27, 2005, 03:12:44 am »
As I mentioned, probably a newbie problem ... ;-)
Oliver, thanks for pushing my nose to the right point!
During my last tests I've checked  the option "XMI 1.0" additionally to "Unisys/Rose" and "Exclude EA Tagged Values".
I thought this is to export a XMI 1.0 with a Unisys/Rose dialect ...
Thanks again.
Ralf
sargasso
« Reply #3 on: October 30, 2005, 07:04:42 pm »
So,  ??? is what we're saying here is that "Rose cannot cope with anything in an XMI file but that which it knows and if it encounters something else it abends." ???
So,  a system that exports XML to a current (possibly MOF) XMI schema must if it wants to retain an ability to interchange with Rose must incur the cost of developing a schema export to match Rose's limitations???
... or am I just being cycnical...
bruce
