Author Topic: C# Reverse Engineering Hanging  (Read 3708 times)
yonigibbs
« on: October 31, 2005, 02:57:15 am »
I'm having problems reverse engineering some C# code.  Whenever I reverse engineer it causes Engerprise Architect to hang (I've left it for over 20 minutes in some cases).  Eventually I have to just kill the process and try again, and what happens most often is that it gets past the class it seemed to hang on last time, then get stuck on the next one.  Is there a way to turn on any debugging information to find out why it's hanging?  Or has anyone else had any similar problems?
Thanks in advance.
Re: C# Reverse Engineering Hanging
« Reply #1 on: October 31, 2005, 01:34:28 pm »
I have encountered a problem with very large files, but it doesn't quite fit your description because got stuck at the same place each time.  You could check if it the same problem by setting EA to not reverse engineer comments.  If that works, then it is likely to be the same problem and EA 6.0 should fix the problem.
If that's not the problem, I would recommend sending in some sample code that replicates the problem to the support email address.
yonigibbs
« Reply #2 on: November 01, 2005, 04:59:56 am »
Cheers, I tried unchecking that option about reverse engineer comments but it doesn't seem to have fixed the problem.  I just need to keep reverse-engineering then when it gets stuck kill the process, then reverse-engineer that class by itself, and most of the time that seems to fix it.  Hopefully EA6 will fix the problem.
« Reply #3 on: November 01, 2005, 01:06:10 pm »
As it doesn't sound like a problem I've seen I doubt it.  But you can always hope.
