Author Topic: map link using automation interface  (Read 4383 times)
Diego_Croda
« on: January 25, 2007, 09:24:57 am »
How to obtain the coordinates to define the MAP for hyperlinks of a diagram using the API of the automation interface?
dkkoenig
Re: map link using automation interface
« Reply #1 on: October 08, 2007, 02:22:08 pm »
i have the same question
« Reply #2 on: October 09, 2007, 06:59:16 am »
AFAIK this is not possible. Hyperlinks seem to be special cases of text elements, with a special setting that determines that they are actually a link - you can examine this if you open the background repository of a hyperlink.
As near as I can determine the field that holds this 'marker' setting is read-only via the API.
Please note: I have not tested this assumption since version 6.5, at which time I issued a feature request to Sparx on the subject. Perhaps it has changed in 7.0, although I got no feedback from Sparx. I have had neither the time nor the requirement to check this since.
