Author Topic: Disabling Security  (Read 3268 times)
martinws
Disabling Security
« on: November 02, 2005, 10:06:56 am »
I've done a very silly thing.
I was trying to disable security on my EAP file. Finding no 'logical' way to do it. I thought if I remove all users the security will be disabled.
Unfortunately not!
Now I still get a login prompt with no user to enter!
I cannot disable security by reentering the security ID since loading the file does not allow me to do it without logging in first!
How can I get back my file? I know, I should have backed it up! But the idea sounded right at the time  ???
Bruno.Cossi
Re: Disabling Security
« Reply #1 on: November 02, 2005, 11:19:18 am »
there might be an easier way, but this might be worth a try:
1. Create a new EAP file
2. Enable the security
3. Open the EAP file using MS Access and copy the table that holds the users (t_user, I think) from the new EAP file to the old one
That should give you user "admin" with password "password".
I do not think that EA should allow deletion of the currently logged on user, that's something that might be worth logging as a bug/feature request.
Hope this helps!
Bruno
Unfortunately not!
« Reply #2 on: November 02, 2005, 01:45:41 pm »
Open the EAP file in MS Access, find the t_secpolicies table and either set the UserSecurity value to "Disabled" or just delete the record. That should fix things.
If you don't have access to Access, zip up the EAP file and email it to us and someone will do the necessary.
Neil
martinws
« Reply #3 on: November 03, 2005, 01:11:46 am »
It certainly did. Am I relieved!   :)
It's good to know you can provide such excellent level of support.
Thanks.
Martin
