Author Topic: Database modeling / populate DB with data?  (Read 2162 times)
Kramer
  • Using EA since 05/2005
« on: November 05, 2005, 12:33:36 pm »
Is there a way to generate database model with some default data created?
I mean, when DDL is generated so it contains some INTERTs ?
I am adding  Instance of Table to database, which should logically be an object inserted into table isn't it? But that doesn't work.
Any ideas ? Is itpossible at all? Or I have to write SQL INSERTs manually?
Thanks.
