Author Topic: Generate XML schema, no datatypes exist!  (Read 2157 times)
Kramer
  • Using EA since 05/2005
« on: November 06, 2005, 01:23:15 pm »
I am trying to export database model as XML.
The only way I found is to use "Generate XML schema" command.
However EA doesn't take datatypes in account for this generation.
Here is the output:
Checking Class: user...ok
Validation Completed
Building XSD classes...done
Initialising XSD classes...done
Adding class attributes...
Warning no XSD type found for: "BIGINT".  Default is: xs:string
Warning no XSD type found for: "VARCHAR".  Default is: xs:string
Warning no XSD type found for: "TEXT".  Default is: xs:string
Warning no XSD type found for: "BOOL".  Default is: xs:string
resulting XSD looks like this:
<xs:complexType name="user">
<xs:sequence>
<xs:element name="user_id" type="xs:string"/>
<xs:element name="login" type="xs:string"/>
All element types are "string".
Is there a way to make it output datatypes correctly?
What template do I need to edit? I spend lot of time at Developer site http://sparxsystems.com.au/resources/developers but couldn't find out.
Thanks.
