Author Topic: Java 1.5 enum code generation error  (Read 2298 times)
davisupmc
« on: November 07, 2005, 11:12:01 am »
It seems as though there is an error in code generation for Java 1.5 enumerations.  Normal 1.5 syntax is
public enum Gender {
Male, Female;}
however, EA generates the following:
private int Male;
private int Female;
this does not work when I try to retrieve the values.  Does anyone have the correct code template for this?
regards
Re: Java 1.5 enum code generation error
« Reply #1 on: November 07, 2005, 01:06:01 pm »
The default java templates require that you stereotype your attributes with "enum".  This is to distinguish between then enumeration values, and the rest of the class that the designers of Java 1.5 included.
You can of course change this behaviour of the templates, so that you need to stereotype your attributes that aren't the enumeration values.  However that will have other consequences if you want to use synchronisation and/or reverse engineering.
« Last Edit: November 07, 2005, 01:08:33 pm by simonm »
davisupmc
« Reply #2 on: November 07, 2005, 01:49:07 pm »
Works!  thanks Simon   :)
