Author Topic: EA crash after SQL connect  (Read 4881 times)
Chaos
  • JUST BRING IT!
« on: November 08, 2005, 05:02:03 am »
My Enterprise Architect crash after a connect to a SQL Server Data Repository.
I am using the Enterprise Architect Corporate Trial Verion and I am testing it for our department. We want manage our Models over a SQL server and so I'm connecting to a server repository...
After selecting the server type and entering the needed details i test the connection. The test succeded an I press OK. Now I can give the connection a name and type. I use the name "EADB_sql" for testing. In the database server dialog is MS SQL Server shown. After pressing OK I am getting an error massage and EA crash.
The massage:
Enterprise Architect has experienced a network error and will close down
I hope that I can find here help. Maybee someone had the same problem and fix it. Thank's for reponses.
greetz Chaos
Re: EA crash after SQL connect
« Reply #1 on: November 08, 2005, 05:28:37 am »
Have you setup the tables with the right scripts from Sparx?
Chaos
  • JUST BRING IT!
« Reply #2 on: November 08, 2005, 06:44:56 am »
Yes, I have setup the tables with the right script and I have also look in the database and the tables exist.
I have also restart the SQL server and nothing changed.
hd
« Reply #3 on: November 08, 2005, 01:08:04 pm »
Have you transferred an eap model to the SQL Server database?
Look up "Upsizing to SQL Server" in the EA Help Index for more details.
Chaos
  • JUST BRING IT!
« Reply #4 on: November 09, 2005, 01:07:02 am »
Bevore I can transfer an eap model to the SQL Server, there must exist a Server Repository or not?
Or is it possible that I can transfer first an eap model and than I can create a Repository?
« Reply #5 on: November 09, 2005, 01:38:20 am »
- Create the repository using the scripts
- open EA
- Tools/Data Management/Transfer
- Copy the contents of an empty EAP (one of the samples) to the repository
- File/Open Project and connect to your SQL server
Chaos
  • JUST BRING IT!
« Reply #6 on: November 09, 2005, 02:32:23 am »
I have tryed it in your order thomaskilian, but nothing changed. I get the massage and EA crash.
I have no idea what it can be.
« Last Edit: November 09, 2005, 07:50:14 am by Chaos »
« Reply #7 on: November 09, 2005, 04:09:01 am »
But the transfer worked?
Chaos
  • JUST BRING IT!
« Reply #8 on: November 09, 2005, 07:55:52 am »
How can i sea that the transfer worked?
Where can I find the entry in the database?
« Reply #9 on: November 09, 2005, 12:58:36 pm »
There should have been some progress information. Also you can look inside the tables using the SQL Enterprise Manager. You should see around a hundred tables with lots of data (esp. t_object).
Chaos
  • JUST BRING IT!
« Reply #10 on: November 10, 2005, 02:30:17 am »
I don't know why, but it works now.  :o
We have changed our network system yesterday and now EA don't crash after connect. Curious, but maybe the old network system was the reason. I can't explain it. I can now wonderfull create Repositorys and work with them. The transfer from .eap to DBMS work fluent without any crashes.
Thanks all that have tried to help me.
Chaos
« Reply #11 on: November 10, 2005, 03:38:59 am »
I'm with you. Just spent the whole morning to kick my windows scripting under XP to accept my Add-In. In the end it looked to me as if I changed nothing - but it works now ;D
