Author Topic: Use Case Metrics: Default Hour Rate  (Read 2816 times)
spereira
« on: November 23, 2005, 04:27:34 am »
What is the Default Hour Rate?
Is it the hours that I effectively work per day?
Thanks!
Sebastian
« Last Edit: November 23, 2005, 04:28:05 am by spereira »
Bruno.Cossi
Re: Use Case Metrics: Default Hour Rate
« Reply #1 on: November 23, 2005, 05:12:39 am »
Hi Sebastien,
the Default Hour Rate is a number of hours you estimate you will need to spend on a Use Case Point. The default method implemented in EA assumes that a Simple UC is an equivalent of 5 UC Point, Medium UC = 10 Points and Complex UC = 15 Points (there are other formulas that use different numbers though).
Chances are it will take you a while until you arrive at a usable number... there is no pre-defined number someone can tell you to use, the number should be based mostly on your historical data.
Bruno
Thanks!
Sebastian
spereira
« Reply #2 on: November 23, 2005, 09:08:30 am »
Thank you very much for your answer.
Sebastian
