Author Topic: EA to output xs:all creating XML Schema, how?  (Read 3160 times)
johnmollaghan
« on: November 24, 2005, 07:46:39 am »
When using the XML Schema profile in EA, how can I specify that the xs:all construct will be used. At the moment it is defaulting to using the xs:sequence construct, not what I want.
VK
Re: EA to output xs:all creating XML Schema, how?
« Reply #1 on: November 24, 2005, 02:02:04 pm »
The default modelGroup for an XSDcomplexType class is 'sequence'. To change this value, select the class and open its tagged-values window. You will see a tag called 'modelGroup' with value 'sequence' - change this value to 'all' .
Cheers.
