Author Topic: How to make an xsd:attribute required using EA  (Read 3917 times)
johnmollaghan
« on: November 24, 2005, 09:00:07 am »
When I add in XSD:Attributes to my complex type, and then generate the schema, it does not specify whether the attribute is required or not. The default seems to be optional.
How can I specify in EA that the XSD:attribute is required?
VK
Re: How to make an xsd:attribute required using EA
« Reply #1 on: November 24, 2005, 02:07:52 pm »
The default value of 'use' for XSDattribute stereotype is 'optional'. To change this value, select the attribute, open its tagged-value window and change the value of the tag 'use' to 'required'.
Cheers.
