Author Topic: Propertys instead of Attribut (Importing Java)  (Read 2517 times)
baz
« on: November 24, 2005, 01:57:47 am »
I'd like to import (reverse engineer) a Java Source directory.
Each of my Sources have a couple of propertys and i like to import them as 'Propertys'
The goal is:
Using 'Hide  property method' in the class diagramm so that only the other methods (not getter or setter) are displayed.
But as far as i discovered all of my propertys are imported as Attributes together with getter/setter Method.
For example:
public class BAZurl {
private String name;
private String url;
public BAZurl(String synonym, String url) {
   super();
   this.name = synonym;
   this.url = url;
public BAZurl() {
public String getName() {
   return name;
public String getUrl() {
   return url;
public void setName(String name) {
   this.name = name;
public void setUrl(String url) {
   this.url = url;
public void blogic(){...}
Only the constructors and the method blogic should show up in the class diagramm after importing this class.
I could change the status of all the attributes(over 300) by hand. And i really have tried this aproach on a couple of classes with a handful of Propertys. But when it comes to synchronization (reverse) the Propertys will become attributes again.
How can i import Java files with all propertys (An attribute with a getter and a setter method) as property?
Ciao,
Carsten
Re: Propertys instead of Attribut (Importing Java)
« Reply #1 on: November 24, 2005, 01:36:45 pm »
EA should identify the properties, so long as you tell it what properties should look like.
Play around with the following settings to get it right.
Source Code engineering
  • Remove Prefixes ...
  • Treat as suffixes
  • Capitalized Attribute name ...
  • Use 'Is' for Boolean ...
Java
  • Get Prefix
  • Set Prefix
Edit: You can even modify the 'New diagram options' on the Import Directory Structure dialog to automatically hide property methods that are imported.
« Last Edit: November 24, 2005, 01:39:47 pm by simonm »
baz
« Reply #2 on: November 25, 2005, 12:25:19 am »
Many many Thanks. That helped. Especially
Ciao,
Carsten
