Author Topic: EA6 and model corruption  (Read 4854 times)
Graham_Moir
« on: November 25, 2005, 04:37:14 am »
I recently upgraded to EA6 and have encountered the following problem/corruption with a model started with EA5.  This is the corporate edition, build 778 in a normal EAP file, no add-ins, no replication, no security with basically one user maintaining the model.
There was only one symptom, namely dragging  packages onto a diagram where they would appear either without showing their contents, or only partially showing their contents.  The diagram properties has "Show package contents" ticked.   No matter what I did (delete the element on the diagram, try again, add/delete elements within the package etc..) the same problem remained.
I then ran Data Integrity.  This found a number of issues all of which seemed to be recovered by the recover process.  I went back to the diagram, only to find the same problem existed.   It was worse however as I now seemed to have duplicates of the package I was dragging on, on the diagram - a condition that isn't allowed by EA normally.  It looked as though now I had a copy  on the diagram for each time I created/deleted the element on the diagram.   None of these duplicates showed the contents of the package properly.   Running data integrity again showed no problems with the model this time.  I therefore resorted to the catch-all XMI import/export.
Good news to report.  After the model was re-imported, all seems to be well.     However a number of questions remain
- any idea what the corruption was ?
- is this an EA6 issue or was it just carried forward from EA5  (if not should we go back to EA5 ?)
- is it likely to re-occur ?   This is a relatively simple model which is a bit worrying, so has anyone else experienced this sort of issue ?  How widespread it is would provide an indicator of how likely it is to re-occur
any comments welcome,
thanks
« Last Edit: November 28, 2005, 01:47:48 am by Graham_Moir »
Re: EA6 and model corruption
« Reply #1 on: November 25, 2005, 11:51:30 am »
Recommendation: report that also to Sparx' support!
Graham_Moir
« Reply #2 on: November 28, 2005, 01:48:05 am »
Done !
Graham_Moir
« Reply #3 on: November 28, 2005, 04:40:50 am »
FYI to everyone, this issue has now re-occurred after a day or so of using the corrected model.   Hopefully a fix will be forthcoming
Graham_Moir
« Reply #4 on: November 30, 2005, 12:54:23 am »
FYI  -  Sparx Support has confirmed this as an issue.   They are targetting a fix for build 780.
