Author Topic: Oracle 10g ?  (Read 6958 times)
girlie
Oracle 10g ?
« on: March 04, 2005, 01:44:35 pm »
Hi - haven't been able to find this anywhere - does anyone know if EA corporate version will work on Oracle 10g?  the specs say 9i...
gulp,
Christine
TBellaver
Re: Oracle 10g ?
« Reply #1 on: March 04, 2005, 01:51:45 pm »
Hmmm,
I have just loaded both on this PC.  I'll try and let you know.
- Todd
girlie
Re: Oracle 10g ?
« Reply #2 on: March 04, 2005, 03:05:33 pm »
Thanks, that would be great and save me doing it!  ::)
Christine
TBellaver
Re: Oracle 10g ?
« Reply #3 on: March 04, 2005, 03:39:01 pm »
Good news ...  It works.  I didn't have any problems connecting.
WAHHOO - Time for the fun stuff!
-Todd
« Last Edit: March 04, 2005, 03:49:07 pm by TBellaver »
girlie
Re: Oracle 10g ?
« Reply #4 on: March 04, 2005, 03:49:14 pm »
Thanks muchly!
Christine
TBellaver
Re: Oracle 10g ?
« Reply #5 on: March 04, 2005, 03:50:57 pm »
heh heh.  no problemo...
- Yes, I am a geek
« Last Edit: March 07, 2005, 07:31:10 am by TBellaver »
girlie
Re: Oracle 10g ?
« Reply #6 on: March 04, 2005, 03:55:52 pm »
Question for me that doesn't know...  I'm following the Oracle instructions I can find on the site and step #4. bothers me.  It just says:
"Run the script to create all of the required tables/indexes etc."
I don't see a script available and I can only assume this is referring to a script I should have created myself for any tables etc..  I need or is there a script somewhere of EA required tables/indexes etc..  I'm supposed to be able to find?
Christine
Bruno.Cossi
Re: Oracle 10g ?
« Reply #7 on: March 04, 2005, 04:44:10 pm »
Hi Christine,
the script is available in the Registered Users section, under Corporate Resources.
Hope this helps!
Bruno
Christine
TBellaver
Re: Oracle 10g ?
« Reply #8 on: March 07, 2005, 07:34:55 am »
I did use the scripts that Bruno mentioned.  Make sure that you grab both Oracle scripts tho.
FYI:  I was also able to export from my existing .eap file into Oracle DBMS using EA's Data Transfer Tool (From the EA Menu Bar >  Tools/Data Management/Data Transfer...)
- Todd
girlie
Re: Oracle 10g ?
« Reply #9 on: March 08, 2005, 10:04:54 am »
Thanks everyone - I'm good to go - successfully set up and have transfered my old model into oracle.
;D
Christine
Justin Halls
Re: Oracle 10g ?
« Reply #10 on: August 26, 2005, 06:33:22 am »
 Does anyone know if EA works with the latest Oracle 10gR2 Database?
Regards
Jeff Odell
Re: Oracle 10g ?
« Reply #11 on: August 29, 2005, 04:18:09 am »
Can one of the posters that made this work verify which version of ODBC they used to connect?  I know that the DDL Import only works with Oracle's ODBC and not Microsoft's and wondered if similar issues exist with the upsizing of an .EAP into Oracle.
Thanks -
jlo
eldon
Re: Oracle 10g ?
« Reply #12 on: October 05, 2005, 03:41:31 pm »
I have tried to connect to Oracle 10g repository. I have a ODBC configured and in operation. I am trying  to connect via Microsoft OLE DB Provider for ODBC Drives  I am connect with Oracle 10g with this driver out from EA, but when I try to connect inside EA the following errors occurs:
Invalid data source...
You must suply a connect name
Funny, because when I test the connect before in EA´s dialog for connection, the test pass.
Any suggestions?
I´m sorry for my bad English
hd
Re: Oracle 10g ?
« Reply #13 on: October 05, 2005, 07:56:14 pm »
To connect to an Oracle repository, use the "Oracle Provider for OLE DB".
Remember to transfer a data model (EABase.eap is a good start) to the repository before attempting to open a project.
To use the import ddl from odbc feature, connect using the Oracle ODBC driver.
JeffM
Re: Oracle 10g ?
« Reply #14 on: December 01, 2005, 11:34:18 am »
Regards
I've just been asked the same thing so I was wondering if anyone knew if Oracle 10g Release 2 was supported by EA?
