Author Topic: Debug Java hangs  (Read 3550 times)
vidafo
Debug Java hangs
« on: November 30, 2005, 12:33:48 pm »
Hello
Thanks to this forum I managed to compile and run a very simple Java Class. Just main method and a simple System.out.println.
When I try to debug this 'application' EA hangs. -> No response in Windows Taskmanager. Even waiting for 5 or 10 minutes ends in the same result.
I've installed the jdk on C:\jdk1.5.0_03 and also an older Version on C:\j2sdk1.4.2_03.
Running java -version on dos prompt results in "1.5.0_03".
Here is my Build, Test, Execute Script contents:
Directory: D:\projects\TestEA6.0\Software
Build CMD
c:\jdk1.5.0_03\bin\javac -g -sourcepath src -d D:\projects\TestEA6.0\Software\bin src\ch\swisslife\prov\dialog\*.java
Capture Output yes, Parser: Java SDK
Test CMD is empty
Run CMD
Run: java -cp bin ch.swisslife.prov.dialog.Test
Debug: ch.swisslife.prov.dialog.Test
Vars: jre=C:\jdk1.5.0_03
Use Debugger: Java
Deploy CMD is empty
Anybody who has a solution?
Btw. there is a similar problemdescription but for .NET.
TX
Daniele
rightmind
Re: Debug Java hangs
« Reply #1 on: December 01, 2005, 06:24:00 pm »
Hi again,
The Directory you specify is
This path will end up being concatenated with any in
the environment variable CLASSPATH
The debugger will set default dir to this folder
and the try and load class:-
ch is actually a subfolder of src (am I right?)
this will fail because the path is not properly qualified
java will try and load a class in
D:\projects\TestEA6.0\Software\ch\swisslife\prov\dialog
I think your debug command should be
src.ch.swisslife.prov.dialog.Test
let me know how you go
Steve
Sparx Systems Support
