Author Topic: Relinking package to a different CVS directory  (Read 2796 times)
StephaneGuerin
  • humm....
« on: November 25, 2005, 04:25:49 am »
I have an EAP file that includes some package under source control (CVS in my case).  For some reason, I have to change the directory structure.  Now when I open EA, I have a message telling me it does not find the "Working copy path YYY for VC config XXXX".  So how I can tell EA where the repository can now be found.
Stephane Guerin
StephaneGuerin
  • humm....
Re: Relinking package to a different CVS directory
« Reply #1 on: December 02, 2005, 04:26:57 am »
Well, not much answer on this one.  Does it means the source control is fixed once for all the life of a EAP file?
Stephane Guerin
mikewhit
  • Accessing ....
« Reply #2 on: December 02, 2005, 06:47:47 am »
I presume you tried removing and reapplying (the new) version control to the package ?
« Last Edit: December 02, 2005, 06:48:20 am by mikewhit »
StephaneGuerin
  • humm....
« Reply #3 on: December 02, 2005, 06:57:55 am »
I tried to remove that package from version control (without erasing it from my model).  However, when I try to set it back under version control, the system refuse because it is already found under system control.
