Author Topic: Nested package under source control  (Read 2819 times)
StephaneGuerin
  • humm....
« on: November 30, 2005, 10:10:27 am »
I'm trying to work with nested package under Source control and it does not seems to behave correctly.  I'm using CVS as the provider.  Here how I have proceeded.
- I checked out a repository to a my local machine
- Setup my EAP to use this repository
- Configured child package to be under source control.  The xml file is exported and commited.
- Configure the root package to be under source control.  The xml file is exported and commited.
Everything seem to be fine there.  Then I go to another station.
- I checkout the repository.
- Setup another EAP file to use the repository
- Do a "Get package" of the previously commited root package.
Now I have in this file the root package and its childs (as expected).  However the child packages are empty!
simon.marshall
Re: Nested package under source control
« Reply #1 on: December 02, 2005, 09:22:33 am »
you have to either Package Control | Get Latest... on the package in question, or Package Control | Get All Latest on any package.
however, you will get problems with diagrams with deeply nested packages under VC, eg, where elements or associations are missing.  checking out/undo checkout the package containing the diagram with missing elements and/or the package containing the missing element.
hopefully it will be fixed in the next release (they say).
StephaneGuerin
  • humm....
« Reply #2 on: December 02, 2005, 09:59:27 am »
I tried this without much success.  My package are still empty.    So the procedure I used is right.  It should work.  I'll enter a bug.
Stephane Guerin
