Author Topic: Links Bent vs. Straight  (Read 4871 times)
cptcook
« on: December 14, 2005, 10:31:08 am »
Greetings,
How do you make the links bend? I can only have them straight lines right now, and I see bent links in the examples.
Re: Links Bent vs. Straight
« Reply #1 on: December 14, 2005, 01:08:47 pm »
Ctrl+Click on the line or right click and select 'Bend line at cursor'
TrtnJohn
« Reply #2 on: December 14, 2005, 03:51:34 pm »
simonm,
In version 6 do you have to set the line style to be custom line before you can bend it?
« Reply #3 on: December 15, 2005, 01:09:26 pm »
No. I can bend lines regardless of what they are set to.
« Reply #4 on: December 15, 2005, 01:43:22 pm »
Makes not much sense with Auto ???
mrelbe
« Reply #5 on: December 16, 2005, 02:51:37 am »
If I may make a wish, I would like to have the possibility to make curvy lines as in Rhapsody...
/Mikael
« Reply #6 on: December 16, 2005, 03:18:43 am »
Place it in suggestions, please.
TrtnJohn
« Reply #7 on: December 19, 2005, 04:41:57 pm »
I had thought I had this problem myself until I noticed that I had set the line style to Direct.  When the line style is set to Direct or Auto Routing then the "Bend Line at Cursor" or Ctrl-Click doesn't work.  (As it shouldn't).  I was just wondering if this might have been the same problem the original poster had.
