Author Topic: Can't connect to server as non administrator  (Read 3076 times)
rburge
« on: January 04, 2006, 07:31:17 am »
I have installed the software and am trying to connect to the server where the model is stored.
I am on a PC with XP pro installed.  The software was installed in administrator account.
When I go to a non admin account I can start up the tool but when I try to connect to the server I go through the connection dialog and it gives me an error that it can't find some software.
If I log back on as administrator and then do the connection I can go through the connection setup just fine and I'm in.  If I change my user account to an admin account again no problems.  When I changed it back I ran into the same problems.
I'm unsure whether or not the problem is EA or the Oracle Client.  Is there a registry setting that must be adjusted?
It would seem to be a permissions issue for non admin accounts.
Your help is appreciated.
Rick
Oliver Michalski
Re: Can't connect to server as non administrator
« Reply #1 on: January 04, 2006, 10:10:57 am »
Hi Rick,
which software cannot find the system?  ???
Oliver  8)
rburge
« Reply #2 on: January 04, 2006, 10:51:35 am »
On the EA main screen I click Connect to Server ...
If I am not an admin then the dialog: Data Link Properties pops up. (When I was admin it popped up and I entered the server particulars).  When I select Oracle Provider for OLE DB another box pops up indicating: Microsoft Data Link Error, Provider is no longer available.
Given that the problem does not present itself when I admin it would seem to be a permissions problem.  Although I'm not sure if it is EA or the Oracle Client with the problem.
Rick
« Reply #3 on: January 08, 2006, 01:29:26 pm »
This seems to be a database authorization problem rather than one of EA. Can you connect with simple tools (e.g. MSQRY32) and show the tables and their contents?
