Author Topic: Conversion into a Sequence diagram  (Read 2454 times)
ecastil1
« on: December 22, 2005, 01:16:09 pm »
Hi. I need generate a sequence diagram. I maked the source code configuration for a .Net application. My build script is "C:\Archivos de programa\Microsoft Visual Studio .NET 2003\Common7\IDE\devenv.com"  /build Debug "D:\Documents and Settings\ecastil0\Mis documentos\Proyectos de Visual Studio\SIPO-2.0.0\sipo.sln". When i try to debug the application (F6 button), i got nothing (there is no answer). why it happens? the code should be in the package? When i run the application from EA "CTRL-Alt-N" it works fine.
ThomasI
Re: Conversion into a Sequence diagram
« Reply #1 on: January 13, 2006, 06:09:30 am »
ecastil1,
Did you ever get this to work?
I have exactly the same problem. I just got the trial for EA yesterday in order to try out generation of sequence diagram, since this is just what I need. I completely unable to get it to work though.
