Author Topic: more same elements in a diagram  (Read 3263 times)
woodz
« on: January 19, 2006, 08:36:40 am »
to avoid a helterskelter of association lines in a class diagram i want to paste a class elemnt once defined as a box without showing the members. I can do this in two seperated diagrams by pasting the elemnt as link. But if I try doing this in the same diagam, EA prompts "...currently only one instance is supportet...".
How can I solve this?
thanks
Tuser
  • So much stuff to do, so little time...
Re: more same elements in a diagram
« Reply #1 on: January 20, 2006, 06:50:08 am »
Why do you want to have the same element twice in a diagram?
One way is to make a diagram only containing the element. Then you drag the diagram into the diagram where you want the element twice and add it as a frame. You can add the same frame multiple times.
However it depends on why you want to do this whether this is a variable solution...
« Last Edit: January 20, 2006, 06:50:35 am by Tuser »
