Author Topic: Generation of Associations as a Property  (Read 4260 times)
dirc
« on: January 19, 2006, 01:57:02 am »
When I define an Association and define a target Role, I can set it to private or public.
What I really want to be able to do is to set it to private and automatically generate a Property for this field.
Further to this, it would be able to be able to optionally set the property to only have a Setter. The reason for this is that I am creating a 0.* association and I want the collection class to be a read only property.
Can anyone give me some pointers as to how to best acheive this?
Many thanks
dirc
Re: Generation of Associations as a Property
« Reply #1 on: January 19, 2006, 02:09:58 am »
You can create getters/setters from within the attribute creation. Once you have attributes you can select them from the drop down in associations. It is not possible to create an attribute from a value entered in an association.
dirc
« Reply #2 on: January 19, 2006, 04:20:52 am »
I know this is not standard behaviour.. I was thinking something along the lines of changing the way the code for an association is generated.
I will put this forward as a feature request.. until then has anyone any clever schemes to get this done?
dirc
« Reply #3 on: January 19, 2006, 01:09:54 pm »
Try using the transformation templates.
The default C# and Java templates do part of what you want, but I'm guessing you want to do a bit more.
Start with that, if it's C# add a readonly tag to the property created if using a collection class (in the Linked Attribute template) and you could even automatically generate add/remove remove methods.
dirc
« Reply #4 on: January 21, 2006, 06:53:12 am »
OK... done it.. does anyone want the template? ;D
dirc
Kevin G. Watson
  • I love EVERYTHING including Microsoft
« Reply #5 on: January 21, 2006, 07:54:57 am »
Yes please
« Reply #6 on: January 22, 2006, 01:28:31 pm »
The EA user group site (http://www.eausergroup.org/) is available for uploading templates etc.  If you want to share a resource for EA that you have made, it is the best place to go.
