Author Topic: VARCHAR2 (.. CHAR) not supported in 8i?  (Read 4524 times)
wzack
« on: December 07, 2005, 10:48:09 am »
Oracle 8i is rejecting the CHAR in VARCHAR2(80 CHAR) generated by EA.  Is CHAR only supported in 10g?
Re: VARCHAR2 (.. CHAR) not supported in 8i?
« Reply #1 on: December 08, 2005, 12:18:20 am »
Shouldn't you ask in an Oracle forum?
wzack
« Reply #2 on: December 08, 2005, 05:07:48 am »
Since EA is supposed to support Oracle and since this code was generated by EA I decided to ask it here.  Shouldn't EA generate valid code for a databas that it alleged to support?
« Reply #3 on: December 08, 2005, 08:44:21 am »
...  Shouldn't EA generate valid code for a databas that it alleged to support?
Of course. But your question was
which is an Oracle related question. Maybe Bruno can help...
Gary W.
« Reply #4 on: December 09, 2005, 04:01:30 pm »
Wzack,
Does your application need to be concerned with representation in various languages (i.e. globalization) and /or different character sets?
The 'char' versus 'byte' qualification is new, and I'm pretty sure it wasn't in 8i.  That may be the problem right there...
How did you even get EA to generate this?  I did a quick test on a table with VARCHAR2 and CHAR columns and didn't get this additional NLS qualifier.
I'm on EA 6.0.778.. what version are you on?
Gary
Bruno.Cossi
« Reply #5 on: December 09, 2005, 04:20:48 pm »
since Thomas invoked my name :-) The ability to declare varchar2 using either byte (default) or char semantics has been introduced in Oracle 9i and is also supported in 10g. I have not seen it generated from EA though, did you type it in the attribute details yourself?
Bruno
donghwi
« Reply #6 on: January 25, 2006, 01:44:23 pm »
I have a same problem and the CHAR come from the reverse engineering from the Oracle 8i.
I'd like to get rid of CHAR from display and also from the DDL generated from EA.
Would it be possible?
Dennis
