Author Topic: Ruby forward engineering  (Read 3888 times)
nicholas_yue
« on: January 24, 2006, 10:24:06 pm »
I am exploring the feasibility of a Ruby forward engineering template.
Looking at the EA documentation, to create a new language type, I need to define a type for that language. The example in the documentation used Java which has built-in type like boolean, int, float, char etc..
As a scripting language, Ruby doesn't seems to have type, how do I proceed?
Cheers
Re: Ruby forward engineering
« Reply #1 on: January 25, 2006, 02:00:58 am »
Add a dummy type
Aaron B
nicholas_yue
« Reply #3 on: January 25, 2006, 10:54:26 pm »
http://www.sparxsystems.com.au/cgi-bin/yabb/YaBB.pl?board=Automation;action=display;num=1123812219;start=0#0
Cool!
I tried following the instruction but the UI seems different in EA 6.1
I created a new language (Ruby) with a dummy type.
I need to have an open project to add a new language. Does that mean that the new language definition is only available for that project? When I open other project, the Ruby language is not available.
The next step you describe was to import the XML file.
Where do I import it? During the new language creation or in the Code Template Editor?
I am keen to try out your templates with EA 6.1.
Thanks in advance.
Cheers
« Reply #4 on: January 26, 2006, 01:04:48 am »
Right. This is per project. You can create a technology file (see the help for that) containing all profile information for Ruby. You can then import that technology into any other model.
nicholas_yue
« Reply #5 on: January 26, 2006, 03:41:48 am »
Is there a summarize steps to do all these with respect to version 6.1.
I have downloaded the ruby code template XML file.
What are the steps required?
I have had a read of the Sparx Help Content and found detailed information about each feature but cannot distilled the actual steps required to achieve the desired outcome.
Cheers
« Reply #6 on: January 27, 2006, 03:38:05 am »
Not sure about that, but I guess it's a technology file. You can import this via the Resource/MDG Tech. window
