Author Topic: Test Cases NUnit results  (Read 2923 times)
alexb
« on: January 25, 2006, 06:39:57 am »
Hello
I'm struggling with the followin problem.
I have a class for which I did NUNIT transformation - the classTest was created.
Quote from manual "Once the unit tests are set up, you can then set up the Build and Test scripts needed to run the tests.  These scripts need to be set up against a package."
Thats fine, but...
1. Can I add unit tests in Test Cases panel and link them somehow with the MessageTest class which realizes them ?
2. If I run nunit from EA can I somehow gather results to fill in relevant fields in the unit test in Test Cases panel?
Kind regards,
Alex
Re: Test Cases NUnit results
« Reply #1 on: January 29, 2006, 08:53:04 pm »
 :-/  No and No.
It's another case of a "Nice Idea we haven't had time to implement yet."
