Author Topic: EA 6.1 SourceGear Vault  (Read 3812 times)
marytdevine
« on: January 27, 2006, 03:28:59 am »
Can someone point me towards a straight-forward guide for adding ea files to source control?
EA appears to add the files to source control ok but then on when the project is next opened source cotnrolmenu items disappear and it recreates new files in source control.  Anyone knwo how this should be setup to get it to work correctly?
The help files only detail what's displayed on the screens so they're pretty useless.
Jeff Odell
Re: EA 6.1 SourceGear Vault
« Reply #1 on: January 30, 2006, 07:28:43 am »
Had you found the Source Code whitepaper?
http://www.sparxsystems.com.au/resources/whitepapers/
I did some brief testing with Vault as I am using it for source code control in development.  Since it is SCC compliant it should work as defined in the white paper.
I'm interested in testing some more with it so if you have issues I wouldn;t mind working through them.
I'm using the latest Vault versions - you?
Jeff Odell
