Author Topic: RTF Documentation  (Read 6367 times)
TimWash
  • Bad news does not get better with age!
RTF Documentation
« on: January 25, 2006, 05:49:47 pm »
Is there any way to save Order by selections from the Generate Options when generating RTF documentation?  I need to set the sort order for elements to Tree Order to get the RTF output sorted correctly.  However, I do not see a way to save that sort preference and I need to set it each time that I generate an RTF report.
Thanks in advance!
Tim
Tim Stevens
Programmer/Analyst
VB.NET, VB6, VBA, T-SQL, ActionScript, ColdFusion
StefanPears
  • Unwissenheit schützt vor Erkenntnis nicht
Re: RTF Documentation
« Reply #1 on: January 26, 2006, 12:44:40 am »
in the template editor: <file>, <document options>. There you find the same generation options frame, but these options are saved with your template.
hth Stefan
TimWash
« Reply #2 on: January 26, 2006, 08:12:05 am »
Thanks Stefan!  This worked just as you said it would.
Tim
Tim Stevens
Programmer/Analyst
kiran
« Reply #3 on: January 30, 2006, 07:17:32 am »
While generating a document the function description is having "bodyLocation = 'source' - Location of method body in C++".
this is getting added to all functional modules by default.
How to get rid of this?
StefanPears
« Reply #4 on: January 30, 2006, 07:29:37 am »
if you use build 785 try 781
Stefan
