Author Topic: Help with section Numbering  (Read 2997 times)
Dana_Maxwell
« on: January 30, 2006, 11:41:22 am »
I'm having a few troubles with section numbering.
I would like the package I'm running the document from to start at level 2. Then each element withing the package would be level 3, including child packages. An sub elements/packages should go to level 4, and so on. See below for a sample.
1.1 Package
1.1.1 Child Package
1.1.1.1 Child Package Element
1.1.2 Package Element
I've been trying to get this to work but for some reason I cannot seem to format the section numbers this way.
I know I've had some limited success with this in the past but I can't seem to figure out how it's done.
I'm using 6.0.781.
Any help is greatly appreciated.
Dana
Jan ´Bary´ Glas
  • Bary
Re: Help with section Numbering
« Reply #1 on: January 30, 2006, 11:42:27 pm »
Dana is not the only one with this problem.
The only chance I see is using Adjust Heading Levels, but I am not sure how to use it to get Dana's results. Have I missed something? Pls help.
Jan 'Bary' Glas
Joel_Melan
« Reply #2 on: January 31, 2006, 04:55:40 am »
hi !
in order to succeed with that problem of deeper and depper numbering, the only way i've found is making a new template from the delivered [Basic] template
It's a hard work but this works !
If I create a new template, all numbering are at fixed level and not relatives !!
The [basic] template uses "Heading" styles (with capital 'h') which are not compatible with MS Word in french, so I wrote a word macro to convert all "Heading" styles in "Titre" styles (french name of numbering styles)
Joel MELAN, casino IT
Joel MELAN, Casino IT
