Author Topic: object size resize problem  (Read 2508 times)
Roger A. Shepherd
« on: January 31, 2006, 08:16:49 am »
I've found a problem.  After minimizing a diagram and resize it back to normal, the size of the objects screwup, they expanded quite a bit making the diagram not easily readable.  Is this a problem or a feature?  :-[
KL
Re: object size resize problem
« Reply #1 on: January 31, 2006, 08:35:56 am »
Just a thought...
I'm not sure what you mean by "minimizing" a diagram, so I have not tried this yet.
Try clicking the "Zoom to 100%" button to see if that restores the diagram image to what it should be. If so, at least your diagram has not changed.
There does not appear to be an explicit magnification setting (as in Word, versus simply 'more' and 'less' zoom). If your diagram problem is resolved by the above trick perhaps you should request an explicit setting as a feature.
