Author Topic: Importing a class exporting function (DLL)  (Read 2139 times)
nicgendron
« on: August 04, 2005, 05:17:35 am »
I'm using EA to do reverse engineering on some C++ code I have.  I this code, I have a Dynamic Link Library (DLL) that exports a class.
The class definition is as follow :
[glb]
class DATALOG_API IDatalog
[/glb]
Where DATALOG_API is defined as this :
[glb]
#ifdef DATALOG_EXPORTS
#define DATALOG_API __declspec(dllexport)
#else
#define DATALOG_API __declspec(dllimport)
#endif
[/glb]
The problem is that EA is seeing this class as "DATALOG_API" and not "IDatalog"
With the consequence that all the links to this class are inexistant.
Is there a way to solve that problem
Thanks a lot
Nic
nicgendron
Re: Importing a class exporting function (DLL)
« Reply #1 on: August 04, 2005, 07:12:17 am »
Configuration menu
Language Macro
Add DATALOG_API
and it works!
larsfl
« Reply #2 on: February 03, 2006, 05:18:33 am »
Did you find a solution?  I have the same problem.
thanks for any suggestions
The languages macro did work ;)
lars
« Last Edit: February 03, 2006, 05:25:11 am by larsfl »
