Author Topic: RTF generation - Error in tagged values  (Read 2919 times)
Tuser
  • So much stuff to do, so little time...
« on: February 02, 2006, 06:53:54 am »
When generating RTF documentation, the tagged values are sometimes duplicated, often with different values!
The tagged value of out requirement stereotype, has the values ID, Delivery, need, ...
Sometimes the fields are repeated for example;
Delivery: D1,
Delivery: D1.
Text: [XXX]
What really surprises me, is that sometimes the repeated value is not the same;
Delivery: D1,
Text: [XXX]
Text: [YYY and not XXX]
The repeated value seems to be an 'old' value. Is EA remembering the old values? Can I disable this?
Else I cannot see any system in the error, and it doesnt happen with all requirements.
Bug or feature?
Re: RTF generation - Error in tagged values
« Reply #1 on: February 03, 2006, 01:23:38 pm »
You can en-/disable duplicate tags in the options. Unfortunately this is only per repository.
Tuser
« Reply #2 on: February 06, 2006, 01:00:44 am »
... the flag is already not set, i.e. duplicate tags are not allowed. I still see them though...
Tried enabling/disabling and then regenerating, but didn't help.
Ideas? Bug or feature?
« Reply #3 on: February 06, 2006, 01:05:13 am »
I'd guess this is a bug then. You should send a bug report. You will likely be requested to send your model. I remember having had similar trouble but now have not since a long time.
Tuser
« Reply #4 on: February 06, 2006, 01:36:04 am »
Ok and thanks.
