Author Topic: MDG Link for VS2005 and Team Foundation Server  (Read 3261 times)
halleck
« on: February 08, 2006, 10:10:31 am »
I've been trying to use the Enterprise Architect 6.1.785 with the MDG Link for Visual Studio 2005. The EA diagram for the solution has been added to the Solution Items, and therefore is a part of the solution. Everything works fine when the solution is not attached to the source control (either VSS or Team Foundation Server).
The problems start when I try to add the solution with the EA model into the Team Foundation (and VSS as well). The Visual Studio does not allow to check in the EA model file into the TFS and says that "The file is being used by another process". I.e. I cannot check in the solution with EA model into the VSS while it is open.
Another issue is when I try to open the EA model after it has been checked in. The Enteprise Architect starts re-spawning all the time, and the EA Model window in VS shows the "Connecting..." message, and that's it. I.e. it is impossible to work on the EA model that has been checked into the VSS.
Haven't found a bug-reporting page, so posting this here.
Thanks.
