Author Topic: Source Code Synchronization  (Read 2334 times)
IceCo
« on: February 14, 2006, 12:34:13 pm »
I am new to Enterprise Architect but already in a position to use this tool to architect a large-scale Flash application.
Here is my situation. I have UML most of my classes in Enterprise Architect and have done a lot of sequence diagrams and class diagrams based on these classes. I then auto generated all the sources codes and started the actual coding/modification.
Now I am in a situation to synchronize my source codes and my UML diagrams. What is the best way to do so?
I tried "synchronize with code" in the context menu and that does nothing. I also tried to import from source codes and check "synchronize" instead of "overwrite" and that still doesn't do the job (it only creates duplicated classes in the .ea file under the same package).  ???
Re: Source Code Synchronization
« Reply #1 on: February 15, 2006, 02:55:25 am »
Search for "roundtrip" in this forum. Come back with more questions then :)
